Okuma Alarm-A 1530 Steady-rests interference position
Steady-rests, Tail stock or W-axis exceeded the interference position and it moved.
Axis
1-> The axis position exceeded the minimal distance.
2-> The axis position exceeded the maximum distance.
1)program error.
2)interference range parameter is not correctly.
1)check the movement command of the axis.
2)set the interference range parameter correctly.
