Okuma Alarm-A 1713 Spindle rotation interlock
In a mode other than MANUAL, the spindle forward/reverse rotation, jog, or orientation command is given with the spindle safety interlock function set at ON.
2->Concerning a spindle orientation pin method, a pin detaching confirmation turned it off during a spindle rotation.
3->A spindle rotation command (including inching,orientation, and C-axis rotation) was issued when the signal for confirming that the grip detector was in retract position was OFF.
9->A spindle rotation command was issued when the tailstock chuck was not unclamped, or the tailstock chuck was during spindle rotation.
10->A spindle rotation command was issued when the spindle chuck was not clamped, or the spindle chuck was unclamped during spindle rotation.
11->A spindle rotation command was issued when the tailstock chuck was not clamped, or the tailstock chuck was unclamped during spindle rotation.
12->A spindle rotation command was issued when the tailstock is not in advance position, or the tailstock moved from advance position during spindle rotation.
13->A spindle rotation command was issued when the tailstock is not clamped, or the tailstock chuck was unclamped during spindle rotation.
14->A spindle rotation command was issued when the tailstock is connected, or the tailstock was connected during spindle rotation.
15->A spindle rotation command was issued when the AJC was not spindle clamped.
16->The AJC clamp confirmation signal went OFF during spindle rotation.
17->Spindle rotation command when workpiece stand was not at its DOWN end-point.
18->The workpiece stand’s “DOWN end-point confirmation” signal switched OFF while spindle was rotating.
19->When centering rod was not retraction, a main spindle rotation instruction wasperformed.
20->Centering rod advanced-retracted command was performed in main spindle rotation.
21->It resulted in the state that centering rod is not retraction in main spindle rotation.
22->In main spindle rotation, pressure detection SW input OFF state of C axis brake continued more than consecutive 1[s]. In main spindle rotation, a state in excess of C axis brake setting pressure continued more than 1[s].
23->When chuck handle is not an accommodation state,. which a main spindle rotation instruction had performed.
24->In main spindle rotation , chuck handle is not an accommodation state.
25->In main spindle rotation , they went along a main spindl low acceleration mode ON/OFF instrunction.
26->when pressure detection SW input of C axis brake was not ON,it did a main spindle rotation command in MANUAL OPERATION mode. Or after it did a main spindle rotation command by M code, even though it did 10[s] progress, pressure detection SW input did not turn it on.
27->A spindle rotation command was issued with the spindle clamped.
28->A spindle rotation command was issued with the C axis clamped or the C axis brake ON.
29->A spindle rotation command was issued with the manual spindle rotation interlock switch ON.
30->A spindle rotation command was issued when a vertical lathe was entering the transfer range or the lathe entered the transfer range when the spindle was rotating.
31->A spindle brake ON/OFF command (M578/M579) was issued when the spindle was moving.
32->An M03, M04, or M19 was issued with the spindle brake output ON.
33->A spindle rotation command was issued when workpiece stand was not insertion position.
34->A spindle rotation command was issued when the centering unit is retract position and unclamp. Or, the centering unit retract confirmation signal was ON during spindle rotation.
35->In main spindle rotation , workpiece stand was not at its DOWN end-point.
36->Spindle rotation command when workpiece stand was upper position and tailstock was advance position and workpiece was in workpiece stand.
37->A spindle rotation command was issued when the work ejector is not in retract position, or the work ejector moved from retract position during spindle rotation.
38->The tailstock index pin IN/OUT command is executed during spindle rotation.
39->The spindle rotation command is executed, when tailstock index pin is not out condition.
40->C axis clamp command was issued when the spindle was moving.
41->A spindle rotation command was issued by air-blow command with C axis clamped or C axis brake ON.
42->Spindle rotation command was issued when chuck clamp and workpieace stand was upper position and tailstock was advance position.
43->When area shutter was not closed,spindle rotation was orderd. Or area shutter was not closed when spindle was rotating.
44->A spindle rotation command was issued when the back chuck cover was not closed, or the back chuck cover was opened during spindle rotation.
45->Spindle rotation command when workpiece stand was not at its UP end-point.
46->The workpiece stand’s “UP end-point confirmation” signal switched OFF while spindle was rotating.
47->The spindle rotation command is executed, when front air chuck pressure lack/ signal is OFF.
48->The spindle rotation command is executed, when front air chuck clamp confirmation signal is OFF.
49->The spindle rotation command is executed, when rear air chuck pressure lack/ signal is OFF.
50->The spindle rotation command is executed, when rear air chuck clamp confirmation signal is OFF.
51->A spindle oscillation command was issued during spindle rotation, or a spindle rotation command was issued during spindle oscillation.
52->A spindle rotation command was issued when the steady rest was not loked. Or steady rest was not unlocked during spindle rotation.
53->A spindle rotation command was issued when coolant pressure dropped. Or coolant pressure dropped during spindle rotation.
54->A main-spindle rotation command was issued when the main-spindle drive jig unit connection confirmation signal was OFF.
55->The main-spindle drive jig unit connection confirmation signal became OFF condition during main-spindle rotation.
56->A main-spindle rotation command was issued when W-axis was in designated position of W-axis. or,W-axis moves to designated position of W-axis during main-spindle rotation.
57->A sub-spindle rotation command was issued when W-axis was not in designated position of W-axis.
58->A sub-spindle rotation command was issued when the sub-spindle drive jig unit connection confirmation signal was OFF.
59->The W-axis is not in designated position of W-axis during sub-spindle rotation.
60->A sub-spindle rotation command was issued when the main-spindle drive jig unit connection confirmation signal was ON.
61->The sub-spindle drive jig unit connection confirmation signal became OFF condition during sub-spindle rotation.
62->The spindle rotation command was issued when the ACC operation sequence number is not start position.
63->The spindle rotation command was issued when the machining station joint is not connect.
64->The spindle rotation command was issued when the machining station pallet is not clamp.
65->A spindle rotation command was issued when the tailstock chuck and spindle chuck was not unclamped, or the tailstock chuck and spindle chuck was clamped during spindle rotation.
66->A spindle rotation command was issued when the spindle front cover is not in close condition.
67->During main spindle rotation, spindle front cover is not in close condition.
68->A spindle rotation command was issued when the magnetic chuck was not magnetization condition, or the magnetic chuck was became de-magnetization condition during spindle rotation.
69->Spindle rotation command was executed, though mismatch between chuck clamp/unclamp command condition and input signal condition was occured.
70->During main spindle rotation, stopper is not advance/retract condition.
71->A spindle inching command was issued during spindle rotation.
72->A spindle rotation command was issued when the Spindle brake Pressure confirmation signal was OFF,or Spindle brake Pressure confirmation signal was OFF condition continued more than 2 seconds at the time of during spindle rotation.
73->A spindle rotation command was issued with the work pusher not at the retracted position, or the work pusher moved from retracted position during spindle rotation.
74->When pressure detection SW input of C axis brake was not ON, it did a main spindle rotation command.
75->The spindle rotation command is executed, when front air chuck clamp confirmation signal is OFF.
Or, A front air chuck clamp confirmation signal is OFF during spindle rotation.
76->The spindle rotation command is executed, when rear air chuck clamp confirmation signal is OFF.
Or, A rear air chuck clamp confirmation signal is OFF during spindle rotation.
77->A spindle rotation command was issued when the steady rest was not clamped. Or steady rest was not unclamped during spindle rotation.
78->A spindle rotation command was issued when the APC pallet was not clamped. Or APC pallet was not clamped during spindle rotation.
79->A spindle rotation command was issued when the APC fork was not in down position. Or APC fork was not in down position during spindle rotation.
80->The tailstock index pin IN/OUT command is executed during C-axis connected.
81->A spindle orientation command was issued with the spindle clamped.
82->A spindle synchoronized tap command was issued with the spindle clamped.
83->A spindle unclamp confirmation signal became OFF condition during spindle rotation.
84->M tool rotation command was issued with the synchronous hobbing mode and the spindle clamped.
85->The spindle rotation command is executed, when front air chuck hook position confirmation signal is OFF.
Or, A front air chuck hook position confirmation signal is OFF during spindle rotation.
86->Spindle position is out of area for air chuck clamp.
87->A spindle rotation command was issued when the ATC shutter was not close. Or ATC shutter was not close during spindle rotation.
88->A tailstock move command was issued while the spindle was in rotation.
89->A spindle rotaion command is issued, when tailstock center is mounted.
90->A spindle rotation command was issued with the measurement sensor unit not at the retracted position, or the measurement sensor unit moved from retracted position during spindle rotation.
Programming error
Program Example:
M03, M04, or M19 is designated with the spindle safety interlock ON.
Operation Example:
The spindle JOG pushbutton is pressed with the spindle safety interlock ON in a mode other than MANUAL.
1)Close the door.
2)If the code 11, 12, or 13 appears, release the alarm by changing the parameter setting (the standard parameter for
switching between chuck work and center work).
