Okuma Alarm-A 1719 Gear command/position mismatch
While the spindle is rotating, commanded spindle speed range gear and the output from the spindle speed range gear position LS have come to be unmatched.
1->While the spindle is rotating, commanded spindle speed range gear and the output from the spindle speed range gear position LS have come to be unmatched.
2->The spindle speed range gear position LS did not accord with the spindle speed range gear order, after the spindle speed range gear selection command was retried.
LS setting error
