Okuma Alarm-A 1721 Gear neutral
The spindle rotation command (M03, M04) is designated while the spindle drive gears are in neutral.
1->The spindle rotation command is designated while the spindle drive gears are in neutral.
Operation error
Select the spindle speed gear range other than neutral (M40) first, then specify the spindle rotation command.
