Okuma Alarm-A 1722 M19 command issued when gear neutral
The spindle drive gear is in the neutral position when the spindle orientation command (M19) is designated.
1)Program error
2)Operation error
Program Example:
The gear range selection command is not designated before the spindle orientation command (M19), or the spindle gear range neutral command is designated before it.
Operation Example:
In the MDI mode, M19 is executed while the gear range is in the neutral position.
