Okuma Alarm-A 1725 Impossible command issued during spindle synchronization
With multi-process machining models (sub-spindle specification models, FTL, etc.), the spindle rotation command, an S command, or the rotation range command for the A-spindle is designated in the spindle synchronized rotation mode. Or with multi-process machining models (sub-spindle specification models, FTL, etc.), the rotation range command for the B-spindle is designated in the spindle synchronized rotation mode. (Assume that the A-spindle is controlled in synchronization with the Bspindle rotation.)
1->M03, M04, M05, or M19 is designated.
2->An S command is designated.
3->Any of M40, M41, M42, M43, and M44 is designated while the 1st spindle is controlled in the synchronized rotation mode.
4->Any of M40, M41, M42, M43, and M44 is designated while the 2nd spindle or the sub spindle is controlled in synchronized rotation mode.
Program error
Program Example:
: G140 : M151 M151 : : G141 M41 S1500 M03 M42 S1000 :
: G140 : M151 M151 : : M150<- Added -> M150 M141 M41 S1500 M03 M42 S1000 :Okuma Alarm-A 1725 Impossible command issued during spindle synchronization
