Okuma Alarm-A 1730 Turret clamp/position check error
The turret clamp signal is turned off during axis movement
[function generation] (except manual operation).
Or a mismatch between tool numbers has continued for more than 1[s].
XYY
X:
None->Mismatch between programmed and actual tool numbers
1->During axis movement [function generation], the turret clamp confirmation signal went out.
2->A mismatch between the programmed tool number and the actual tool number is found after the turret has been clamped
3->A cutting feed command is issued while the NC turret is unclamped, and the turret is not clamped within 500[ms] after designation of the command.
4->The command of cutting-feed was performed by the state that was not “M-tool spindle edge angle” when L-tool or sensor is registered with present-tool.
5->The rapid feed or manual jog feed or puluse handle feed command is issued, while the NC turret is not clamped and turret index motor’s servo is OFF.
7->Turret positioning is not finished.
YY:Hexadecimal number of designated tool number
FFFFFFFF:A tool index command other than T1 was issued when an NC round table or stationary turret was mounted.
1)An abnormality occurred in the turret clamp confirmation limit switch, turret-related wiring, or the turret index limit switch.
2)T-axis position encoder offset value
X=None->Check the EC input related with the tool number.
X=1, 4 or 5->Check the clamp confirmation LS.
X=2->Check the EC input related with the tool number;
adjust the turret index solenoid when the turret overpasses the designated position.
