Okuma Alarm-A 1743 Index chuck interlock
A spindle rotation command was issued with the chuck not being indexed and the index completion signal OFF.
Conditions for indexing were not met when an index command was issued.
An insufficient index chuck fluid pressure
1->A spindle rotation command was issued with the chuck not being indexed and the index completion signal OFF or the signal turned OFF when the spindle was rotating.
2->The chuck was not indexed within the preset time.
3->An index command was issued with the Z axis not at the positive limit.
4->An index command was issued with the chuck not clamped.
5->An insufficient index chuck fluid pressure.
6->An index command was issued, when the index confirmation input signal was irregular condition.
7->The chuck was not indexed at the goal position, or the index confirmation input signal was irregular condition at the goal position.
8->index chuck control oil was shortage condition.
9->An index command was issued, when spindle rotated over the number of index permission parameter during spindle rotation.
10->An index command was issued, when index chuck selection switch was not selected the effective mode.
11->Position request alarm.
12->Position alarm.
13->Sequence error.
