Okuma Alarm-A 1753 Parts catcher interlock
Parts catcher interlock is activated when an attempt is made to advance or retract the parts catcher.
0->The parts catcher advance command is designated when the Z-axis is not at the positive end limit. Or an axis move command is designated while the parts catcher is at the advance position.
1->The parts catcher advance command is designated when the door is not closed.
2->The parts catcher advance or retract command is designated when the touch setter is not at the retract end.
3->The parts catcher advance or retract command is designated when the door is not closed.
4->The parts catcher advance or retract command is designated when the ZB-axis is not at the positive end limit. ZB-axis move command is designated while the parts catcher is not at the retract end. Or the parts catcher is placed at a position other than the retract end while the ZB-axis is moving.
5->The parts catcher retract command is designated when the parts catcher is not at the swing-up end or while the parts catcher is going down.
6->The parts catcher swing up or down command is designated when the parts catcher is not at the advance end or while the parts catcher is retracting.
7->A command to move the parts catcher to the workpiece receive position or retract position is designated when the parts catcher is not at the advance end or while the parts catcher is going up.
8->A command to swing the parts catcher forward or backward is designated when the parts catcher is not at the advance end or while the parts catcher is retracting.
9->A command to swing the parts catcher forward or backward is designated when the parts catcher guide axis is not at the retract end or while the parts catcher is advancing.
10->The parts catcher arm retract command is designated when the parts catcher is not at the swing end position in the forward direction or while the parts catcher is advancing.
11->The parts catcher guide axis advance command is designated when the parts catcher is not at the swing end position in the backward direction while the parts catcher is advancing
12->Parts catcher advanced-retracted command was performed by the state which became disconnected in XA, ZA axis plus limit place. Or, an axis movement instruction was performed by a parts catcher advanced state and it was.
13->When it was not a Main spindle stopped state, parts catcher advanced-retracted command was performed. Or,a main spindle rotation instruction was performed by a parts catcher advanced state.
14->Except for XA, ZA axis plus variable limit position, a rising order of a parts catcher or a descent order was performed. Or, an axis movement order was performed by a decline condition of a parts catcher.
15->When it was not in a Main spindle stop, it performed a rising order of a parts catcher or a descent order. Or, it performed a main spindle rotation order by a decline condition of a parts catcher.
16->Though shot work confirmation input had not turned it on by automatic operation, door open-close command was performed.
17->Though shot work confirmation input had not turned it on by automatic operation, a rising order of parts catcher was performed.
18->Door open-close command was performed by the condition which is not a rise of a parts catcher.
21->The parts catcher advance or retract command is designated when the XB-axis is not at the positive end limit.
22->The parts catcher advance or retract command is designated when the ZB-axis is not at the workpiece chuting position (set at parameter (long word) No. 1).
23->The parts catcher advance or retract command is designated when the W-axis is not at a position within the operation enabled range (set at the parameter (long word) No. 2).
24->The parts catcher advance or retract command is designated while the sub spindle is rotating. Or, when there was not a parts catcher in retraction edge, a sub spindle rotation instruction was performed.
25->The parts catcher advance or retract command is designated when the door is not closed. However, parts catcher advanced-retracted command was performed by the state that there is not on R side door close in the case of ‘LT specification + sub spindle specification ‘.
26->A command to move the XB- or ZB-axis is designated when the parts catcher is not at the retract end. Or the parts catcher is placed at a position other than the retract end while the XB- or ZB-axis is moving.
27->A command which moves the W-axis toward the workpiece chuting position exceeding the workpiece transfer position is designated when the parts catcher is not at the retract end.
30->When there was Za axis on place on the side of plus more Za axis operation possibility place, parts catcher advanced/retracted command was performed.
31->When there was Zb axis on place on the side of minus more Zb axis operation possibility place, parts catcher advanced/retracted command was performed.
32->When there was Zc axis on place on the side of plus more Zc axis operation possibility place, parts catcher advanced/retracted command was performed.
33->The Za axis moved to the side of plus more Za axis operation possibility place when the parts catcher is not at the retract end.
34->The Zb axis moved to the side of minus more Zb axis operation possibility place when the parts catcher is not at the retract end.
35->The Zc axis moved to the side of plus more Zc axis operation possibility place when the parts catcher is not at the retract end.
36->When the touch setter of R-spindle side is not retract position, a parts catcher advance/retract command was done.
37->When the parts catcher is not retract position, the touch setter of R-spindle side is placed at a position other than the retract end
40->When there was ZB axis on place on the side of plus more ZB axis operation possibility place, parts catcher advanced/retracted command was performed.
41->When the W-axis was not in the specified W-axis position, a parts catcher advance/retract command was issued.
When the parts catcher was not in retract end, a command was issued to move the W-axis in the minus direction beyond the specified W-axis position.
42->When it was not touch setter retraction edge, parts catcher command was done. Or, when there was not a parts catcher in retraction edge, a touch setter was not retraction edge and became.
43->When it was not parts catcher retraction edge, axis transfer instruction on the side of plus was done from ZB axis operation possibility place.
44->When it was not parts catcher retraction edge, XB axis transferred in the direction of a minus.
45->The parts catcher advance command is designated when the unloader carrier2 is not at the retract position.
Related Specifications
Parts catcher
