Okuma Alarm-A 1756 Loader inside machine
Lathe with Auto Loader/Robot Door:Loader at Waiting Position Code is Off. Door Closed Code is On, or Door Close Command is issued; whenSynchronized Peripherals at Waiting Position Code is off. Spindle Revolution, Sub-Spindle Revolution,or Milling Tool Revolution Command is issued;when Synchronized Peripherals at Waiting Position code is off. Traverse or Turret Index Command is issued; when Synchronized Peripherals at Waiting Position code is off. Ceiling Door Close, Front Door Close, Contour Generation, or Spindle Revolution Command is issued; when Loader at Waiting Position Code is Off.
1->NC Loader: Spindle Revolution or Sub-Spindle Revolution Command is issued; when NC Loader is Not outside Lathe.
NC Loader: The actual Spindle/Sub-Spindle speed is above a Specified Limit; when NC Loader is Not outside Lathe.
2->NC Loader: MA/MB Revolution Command is issued;
NC Loader: The actual MA/MB speed is above a Specified Limit; when NC Loader is Not outside Lathe.
3->Door Closed Code is On;
Door Closed Code is On, or Door Close or Ceiling Door Close Command is issued;
NC Loader, Lathe without Ceiling Door: Front Door Open Code is Off;
when NC Loader is Not outside Lathe. NC Loader, Lathe with Ceiling Door, under Synchronized Mode: Front Door Closed Code is ON, and Ceiling Door Open Code is Off;
when NC Loader is Not outsideLathe.
NC Loader, Lathe with Unified Ceiling Door,Not under Synchronized Mode:
[Front Door Open Code is On,and Ceiling Door Closed Code is Off],and [Front Door Closed Code is On,and Ceiling Door
Open Code is Off]; when NC Loader is Not outside Lathe.NC Loader, Lathe with Non-Unified Ceiling Door,Not under
Synchronized Mode: Ceiling Door Open Code is Off; when NC Loader is Not outside Lathe.
4->Traverse Command is issued;
when Synchronized Peripherals at Waiting Position code is off. Synchronized Peripherals at Waiting Position Code is off; during Traverse.
5->Door Open Code is Off;
NC Loader:
NC Loader is Not outside Lathe; during Turret Indexing.
7->Spindle table rotation command was issued when when NC Loader is Not outside Lathe.
8->Spindle table unclamp command was issued when when NC Loader is Not outside Lathe.
9->A loader alarm has occurred when the loader was entering the machine interference range.
Move Loader/Robot/Peripherals to outside Lathe.
