Okuma Alarm-A 1763 Tool revolution interlock
The M-tool rotation command is designated under the condition that the M-tool spindle must not rotate, or the condition of the Mtool spindle rotation turns off during the M-tool spindle rotation.
1->The M-tool rotation command is designated when the C-axis is not connected.
2->The M-tool rotation command is designated when the ATC tool (M-tool) is unclamped.
3->When spindle orientation pin incoming confirmation had not entered it, a M-tool spindle rotation instruction was performed.
Concerning ATC specification machine type, a M-tool spindle rotation instruction was performed by the state which attached measure sensor to turret for M tool securing pin.
By ATC postion index command, though they are about to carry out, since measure sensor is attached to turret for M tool securing pin, a M tool spindle orientation can not be done performance.
4->The M-tool spindle rotation command is designated while the spindle is rotating.
5->The M-tool spindle rotation command is designated when the turret is not clamp condition.
6->In the spec of H1-Turret:
It is the state of M-axis Clamp or L-tool Confirmation.
L-tool or sensor is registered with present-tool.
7->Concerning ATC specification machine type, the M-tool spindle rotation command is designated when the M-tool is not clamped.
8->The turret clamp signal is turned off while the M-tool spindle is rotating.
9->Concerning ATC specification machine type, the M-tool rotation command is designated when the ATC tool (M-tool) is not exist (the no tool signal is on).
Concerning ATC specification machine type, the M-tool rotation command is designated , when the ATC tool (M-tool) is not exist(the no tool signal is on) or actual tool data is not set.
10->Concerning ATC specification machine type, the no tool signal is turned on while the M-tool spindle is rotating.
Concerning ATC specification machine type, the M-tool rotation command is designated, when the ATC tool (M-tool) is not exist(the no tool signal is on) or actual tool data is not set.
11->Concerning H1 turret specification machine type,M-tool spindle unclamp confirmation is turned off while the M-tool spindle is rotating.
12->M-tool revolution command was performed with special tool selection.
13->The through spindle air blow output did on in M-tool rotate, after the through spindle coolant output turned off and the parameter-set time progress.
14->The M-tool spindle rotation command is designated when the M-tool spindle is not clamp condition.
15->The M-tool spindle rotation command is designated when the turret is indexed in L-tool position.
16->The M-tool spindle rotation command is designated when Measurement sensor unit is not in retract position.
1)Program error
2)Operation error
Program Example:
N100 M109 C-axis disconnected
N101 M13 M-tool spindle FWD
3)By ATC specification machine type, the turret which M tool rotation command can instruction has been decided and M tool rotation command can not be performed by turret of exception.
Even the state which attached measure sensor to turret for M tool securing pin can not be done M tool rotation command.
