Okuma Alarm-A 1772 Door open/close condition
With the ceiling door open, a front door open/close command was issued. Or, with the front door open, a ceiling door open/close command was issued.
1->With the front door open, a ceiling door open/close command was issued.
2->With the ceiling door open, a front door open/close command was issued.
3->The ceiling door open command was issued during spindle rotating.
4->The ceiling door open command was issued during axis movement.
5->The ceiling door open command was issued during turret indexing.
6->The front door open command was issued when spindle rotating.
7->The front door open command was issued during axis movement.
8->The front door open command was issued during turret indexing.
9->The ceiling door open command was issued during M-tool rotating.
10->The front door open command was issued during M-tool rotating.
11->A right door open/close command was issued with the operation panel not fully stored.
13->A ceiling door open command was issued with the loader continuous operation signal ON and the front door open.
14->The door open/close command was issued during door sensor failed. or, door sensor failed during door movement.
15->When different operation mode was selected between R-side and L-side machine, a front door open/close command was issued.
16->When the door lock cancel permission signal from loader I/F was OFF, a front door open/close command was issued.
17->The different direction front door open/close command was issued between R-side and L-side machine.
18->When a footstool was advance position, a front door close command was issued. or. a footstool moved to advance position during a front door close.
19->With the ceiling door close, a front door open/close command was issued.
20->The door close command was issued when ACC table is not down.
21->The door close command was issued when ACC cycle start.
22->On the NC door specification, the door open/close pulse handle parameter of the Machine user parameter is ON.
23->The door effective key switch at the machine panel is not ON.
24->Both front door and ceiling door were open.
25->With the window on the flont door open, a front door open/close command was issued.
26->In dual palm door open/close operations, it was let go off either button during open/close the door.
27->Safety guard is open.
28->The door close command was issued when the door state was uncertain.
29->The door open/close command was issued the door was not ready for operation.
30->The main door open/close command was issued when the swing door was not closed or the swing door opened when the main door was being opened/closed.
31->The main door open/close command was issued when the operator door was not closed or The operator door opened when the main door was being opened/closed.
32->The ceiling door open/close command was issued from the loader with the ceiling door guide advance confirmation signal off.
33->APC door open command was issued when spindle rotating
34->APC door open command was issued during axis movement
35->APC door open command was issued during M-tool rotating
36->With APC door open, the front door open command was issued.
