Okuma Alarm-A 1773 Unable to restore axis position when door closed
On the machine intended for CE marking, the magnet switches in high-precision VAC and servo amplifier are turned off by opening the door and turned on by pressing the reset switchor closing the door. When the switches change their status from OFF to ON, the following conditions are not met.
1)The feed axis (including the spindle under C-axis control) is at least 0.5[mm] away from the position detected when the magnet switch was turned off.
2)The spindle or M-tool spindle in the state of orient-stop, synchronized rotation, or flat turning is at least 0.36.(equivalent to 0.5[mm]) away from the switch OFF position.
SYSTEM, AXIS, M-TOOL SPINDLE
