Okuma Alarm-A 1775 Touch setter limit
The signal for confirming that the touch setter arm is in retract position is turned OFF while any of spindle, M-axis, and C-axis is rotating or while the turret is moving or rotating in a mode other than MANUAL or MANUAL INTERRUPT.
Or, the signal for confirming that the touch setter is in advance position is turned OFF during execution of touch setter cycle.
1->Touch setter arm retract position signal is OFF during spindle rotation.
2->Touch setter arm retract position signal is OFF during M-axis rotation.
3->Touch setter arm retract position signal is OFF during C-axis rotation.
4->Touch setter arm retract position signal is OFF during turret movement.
5->Touch setter arm retract position signal is OFF during turret rotation.
6->Touch setter arm retract position signal is OFF when W-axis is not in the plus limit.
7->Touch setter arm retract position signal is OFF when the spindle chuck is not open.
8->Touch setter arm retract position signal is OFF when the sub-spindle chuck is not open.
9->Touch setter arm retract position signal is OFF when the door is not closed.
10->Touch setter advance position signal is OFF during execution of touch setter cycle.
11->Touch setter arm retract position signal is OFF when the burr removing device is in retract end.
12->The touch setter advanced during coolant supply.
13->The touch setter advance/retract signals turned ON at the same time.
14->The touch setter right and left retract position signals turned ON at the same time.
15->The touch setter cover open/close signals turned ON at the same time.
1)Malfunction of the EC input signal for detecting the sensor head position (I/O check NO.26 INPUT bitE (iSHRTC) or bitF
(iSHADC)).
2)Programming errorThe gauging subprogram was called without designation of M137.
Program Example:
M117 CALL OTFRD
1)Recheck the program.
2)If the alarm is not related to the gauging cycle, check the EC input signal.
