Okuma Alarm-A 1777 ATC change arm position error
Rotation localization input of exchange arm of ATC or positioning localization input does not input rightly.
XX
10->When there was rotation localization input of exchange arm or positioning localization input in an interference place with turret, they went along a turret rotation instruction.
By LB35II-MATC -Y LU45-MATC-Y, it is possible turret rotation in EA rotation A place or EA rotation C place.
By LB15II-MATC-Y, it is possible turret rotation by EAMG place or EA standby place.
11->After control software install, each rotation place confirmation input of exchange arm has turned it off all at the time of build up of beginning. In NC-ATC specification ATC apparatus, this alarm certainly generation at the time of build up at the beginning of control soft wear install posterior. When parameter of a rotation place of the exchange arm that there is in a system parameter setting screen of parameter setting mode is used again a power supply after setting, this alarm disappears.
