Okuma Alarm-A 1789 Steady rest interlock
The XB or ZB or W axis was moved with the steadyrest not unclamped.
A steadyrest advance/retract command was issued with the steadyrest not unclamped.
A steadyrest command was issued when the spindle was rotating.
A spindle rotation command was issued with the steadyrest closed and not at the advance end.
The steadyrest opened and left the advance end when the spindle was rotating.
One of Steady Rest Operating Conditions is Not met.
1->XB/ZB/W-Carriage or Turret B Mounted Steady Rest: Turret Traverse Command is issued; when Steady Rest Open Code is Off.
2->Relieving Type Steady Rest: Steady Rest Traverse Command is issued; when Steady Rest Open Code is Off.
3->Steady Rest Command is issued; during Spindle Revolution.
4->Spindle Revolution Command is issued; when Steady Rest Closed Code is Off. Steady Rest Closed Code is Off, during Spindle Revlution.
Steady Rest Closed or Steady Rest at Advancing Limit code is Off; during Spindle Revolution.
7->Steady Rest Traverse Command is issued,when Steady Rest Switch is set at Off.
8->Steady Rest Traverse command is issued when Steady Rest clamped code is off.
9->Steady Rest Close command is issued when Steady Rest saddle clamped code is off.
11->XB-Carriage Steady Rest: Turret indexing position free command is issued.
21->XA-Carriage or Turret A Mounted Steady Rest XA/ZA/ZC, Y-Axis Traverse Command is issued when Steady Rest Open Code is Off.
22->W-Axis Traverse Command is issued when Steady Rest Open Code is Off.
31->Turret A Mounted Steady Rest: Turret indexing position free command (M66) for A Turret is issued.
41->A lower turret home position command was issued with the lower turret mounted and the steadyrest not unclamped.
42->A turret rotation command was issued with the lower turret mounted and the steadyrest not fully closed.
43->Turret B Mounted Steady Rest: Steady Rest Command is issued, when Steady Rest was not index position.
44->Turret B rotation command (T code) was executed with the XB axis of turret B not at the positive limit.
45->Steady Rest Open Command was issued when the arm was locked.
46->Arm Lock Command was issued when steady rest was opened.
47->Arm Unlock Command was issued during spindle rotation.
48->Turret B Mounted Steady Rest: Turret Traverse Command is issued; when Steady Rest effective switch was sat OFF.
49->A steadyrest advance command was issued when tailstock was not advanced.
50->A tailstock retract command was issued without locating the steady rest at the retract end.
51->Steady rest(W-axis) movement command was issued, when X-axis was not plus limit position.
52->ZB/W-Carriage NC Steady Rest Traverse Command is issued; when Steady Rest Open Code is Off.
53->At the time of manual interrupt mode, while main spindle rotating the front door became not closed status and the steady rest became not closed status.
54->Turret B Mounted Steady Rest: Door open close command was issued with the Steady Rest was not index position and Steady Rest not fully closed.
55->The Steady Rest ON/OFF Switch turn ON when the B-turret rotation position is not “B-turret pot attached steady rest position”.
56->XB-Axis position is not “XB-axis designated position” when the Steady Rest ON/OFF Switch is set at ON.
57->XB/W-Axis Traverse Command is issued when the Steady Rest ON/OFF Switch is set at ON.
58->The steady rest ON/OFF switch turn on when the steady rest unit is unclamp condition.
59->XD/XE/XF/ZD/ZE/ZF/W-axis move command was issued when steady rest is not unclamped or steady rest is not opened.
60->Chuck unclamp or W-axis move command was issued when the number of steady rests to be holding work is not much.
61->A cutting-feed command was issued, when steady rest was closed and steady rest saddle was not clamped.
62->ZB/ZD/ZE/ZF/W-axis move command was issued or ZB/ZD/ZE/ZF/W-axis moved when R-spindle chuck and steady rest are not unclamping workpiece.
63->Even though Steady Rest ON/OFF Switch is set at OFF, the Steady Rest is mounted.
