Okuma Alarm-A 1799 Sensor protection cover interlock
An attempt has been made to open or close the sensor protection cover while its open/close is not possible.
While sensor protection cover is not close the spindle rotation command (M03, M04) or M-tool rotation command (M13,M14) is issued.
1->The sensor protection cover open/close command is designated while the spindle stop requirements are not satisfied:
2->The sensor protection cover open/close command is designated when the M-tool spindle is rotating.
3->The sensor protection cover open/close command is designated when the C-axis is rotating.
4->The sensor protection cover open/close command is designated while the turret is not at the travel end of Z-axis
5->The tool breakage sensor was not closed position during spindle rotation.
Or, spindle rotation command was designated, while the tool breakage sensor cover was not closed position.
6->The tool breakage sensor cover was not closed position during M-spindle rotation.
Or, M-spindle rotation command was designated, while the tool breakage sensor cover was not closed position.
7->The tool breakage sensor cover was not closed position during axis movement or C-axis movement.
Or, axis movement or C-axis movement command was designated,while the tool breakage sensor cover was not closed position.
8->The tool breakage sensor cover was not closed position during turret indexing.
Or, turret index command was designated, while the tool breakage sensor cover was not closed position.
