Okuma Alarm-A 1830 SP. oil air lub. oil level error
The oil level in the oil-air spindle lubrication tank is too low.
A oil-air lubricant liquid surface fall condition continued more than 3 seconds.
1-> A M SP.oil-air lubricant liquid surface fall condition continued more than 3 seconds.
1) An insufficient oil-air spindle lubricant level
2) A faulty oil-air spindle lubricant level sensor
1) Supply oil to the oil-air lubrication unit for spindle.
2) Change the sensor for monitoring the oil level of the oil-air lubrication unit with a new one.
