Okuma Alarm-A 1838 Workpiece stabilizer interlock
Concerning work stabilizer control, a condition is not satisfied.
2->It was the following conditions at the time of steady rest Z directional advanced/retracted command.
(At the time of Z directional advanced/retracted command)
It was not steady rest open at the time of steady rest selection.
It was not Turret X/Z plus variable limit.
(At the time of Z directional retracted command)
It was not Z directional grasp position and X directional advanced end limit position.
(At the time of Z directional advanced command)
It was not sensor head retracted position.
It was not Z directional retracted position.
Shortstop/long renewal input was illegal at the time of support equipment selection.
It was not X directional advanced end limit position at the time of support equipment short selection or steady rest selection.
It was not X directional retracted position at the time of support equipment long selection.
3->It was the following conditions at the time of steady rest original point return/retract position movement order.
(At the time of original point return/retract position movement order)
(At the time of an original point return order)
It was not Z directional advanced position and X directional retracted position.
(At the time of a retract position movement order)
It was not X directional advanced position at the time of support equipment short selection or steady rest selection.
4->It performed Z directional advanced/retracted command in main spindle rotation at the time of support equipment selection.
5->It is not a support equipment support position in main spindle rotation at the time of support equipment selection. it performed a main spindle rotation order.
6->It was the following conditions at the time of steady rest X directional advanced/retracted command.
It was not Z directional retracted position at the time of support equipment selection.
It was not Z directional retracted position or a grasp position at the time of steady rest selection.
