Okuma Alarm-A 1843 Workpiece rest interlock
1->A work rest up/middle/down command was issued when the spindle was moving.
Or a work rest was not down position when the spindle was moving.
2->An up to middle position work rest move command was issued with the tailstock sleeve not at the retract end.
3->A middle to up position work rest move command was issued with the tailstock sleeve not at the retract end.
4->A work rest insertion/removal position (right/left slide move) command was issued with the tailstock sleeve not at the retract end.
5->An escape (down) to setting (middle) position move command (M545) or setting (middle) to escape (down) position move command (M546) was issued with the work rest at the work-out (up) position or an M546 was issued when the work rest was stopping in the middle.
6->A work-out (up) to setting (middle) position move command (M543) or setting (middle) to work-out (down) position move command (M544) was issued with the work rest at the escape (down) position or an M544 was issued when the work rest was stopping in the middle.
7->A work rest up/down command (M544/M543) was issued with the work rest not at the retract end.
8->An axis command was issued in AUTOMATIC or MDI mode with the work rest connected with the tow-along tailstock.
9->The Z axis motor load exceeded 70% of the rated load for 0.1 second or longer with the work rest connected with the towalong tailstock.
12->A work rest up/down command was issued when work rest was not left position.
13->A work rest up/down command was issued when work rest securing pin was not extract position.
14->A work rest up/down command was issued when spindle was not in the state of orient-stop.
15->A work rest up/down command was issued when turret A and turret B not at the positive limits.
16->A work rest up/down command was issued when tailstock was not advance position.
17->When the tailstock sleeve was not at the retract end, command of workpiece stand move was issued.
18->When the tailstock by chuck was retracted, a downturn order of workpiece stand was issued.
19->XB axis is not plus limit position or a workpiece stand is index position during tail stock moving.
20->ZB axis move command was issued, when tailstock was not retract position or chuck was not unclamp condition.
21->Overload of ZB axis motor applied with chucking a work.
22->A middle to up possition work rest move command was issued when X-axis was not at the positive limits.
23->A middle to up possition work rest move command was issued work rest was not at the removal position.
24->A work rest up command was issued when the touch setter was not in retract position.
25->A middle to up position work rest move command was issued work rest was not at the insertion position.
26->A spindle rotation command was issued with the work rest not at the down position, or the work rest moved from down position during spindle rotation.
27->A work rest advance/retract (insertion/removal position) command was issued when the spindle was moving. Or A work rest was not in insertion position when the spindle was rotating.
28->A spindle rotation command was issued with the Work rest not at the retracted position.
29->A tailstock quill advance command was issued with the Work rest not at the retracted position.
30->NC axis moving command is given with the chuck are not unclump conditon at the Work rest indexed position.
36->A work rest insertion/removal position command was issued when the chuck was not unclamped.
37->ZB axis move command was issued, when the work rest not at the retracted position.
38->A work rest up/down command was issued, when there was work on work piece stand and tailstock was not advance position.
39->A spindle rotation command was issued with the work rest not at the insertion(advance) position, or the work rest moved from insertion(advance) position during spindle rotation.
40->A spindle orientation command was issued with the work rest not at the removal(retract) position.
41->A spindle orientation command was issued with the work rest not at the up position.
42->A work rest up/middle/down command was issued when the chuck is not unclamped.
43->A Chuck clamp command was issued with the Work rest not at the retracted position.
44->A work rest eject/unload/retract command was issued when X-axis was not at the positive limits.
45->A work rest unloading command was issued with the work rest not at the ejection or retract position.
46->A work rest down command was issued, when there was work on work piece stand.
47->A work rest up command was issued when the chuck was not unclamped.
48->A work rest up command was issued with the spindle center not at the retract end.
49->A work rest up/down command was issued when X-axis was not at the positive limits.
50->Work rest up/down command was done when the work rest was on a minus side from work temporary insertion position.
51->Work rest up command was done when the work rest was in the range of interference.
52->X axis movement command was done when the work rest was on a minus side from the retract position with the interference tool calculated.
