Okuma Alarm-A 1849 Workpiece unloading unit interlock
A work-out unit up command was issued when the spindle was rotating.
1->A work-out unit up command was issued before the spindle completely stopped at the regular position.
2->A spindle rotation command was issued with the work-out unit not at the lower end.
3->A tailstock quill advance command was issued with the work-out unit not at the lowered position.
4->A work-out unit up command was issued with the tailstock quill not at the retracted position.
5->A work-out unit up command was issued with the backup roller not at the retracted position.
6->A work-out unit up command was issued when the spindle was moving.
7->A spindle rotation command was issued with the work-out unit not at the lowered position.
8->The work-out unit left the lowered position when the spindle was moving.
9->A work-out unit advance/retract command was issued with the chuck closed.
10->A chuck close command was issued with the work-out unit not retracted.
11->XB axis or ZB axis moved when it did not meet the following condition. Or it did not meet the following condition when XB axis or ZB axis was moving.
(condition) work-out unit hand open, or (chuck unclamp and tailstock retract position)
12->B-turret index command was issued when XB axis is not at a plus variable limit.
13->A spindle rotation command was issued when the work-out unit hand was not open. Or work-out unit hand open/close command was issued during main spindle rotation.
14->A work-out unit up command was issued with the chuck not at the opened.
15->Turret index command was issued when Work-out unit hand is not fully closed.
16->Work-out unit up command was issued when work-out unit is not advance position. Or work-out unit was not advance position when when work-out unit is moving up.
17->Work-out unit up command was issued when front door is not open. Or front door is not open when work-out unit is moving up/down.
18->Work-out unit up/down command was issued when XB/ZB axes are moving.
19->Work-out unit up command was issued when B-turret is indexing.
20->Work-out unit up/down command was issued when work hand is not unload position.
21->XB/ZB axes moving command was issued when work-out unit is not down position. Or work-out unit was not down position when XB/ZB axes are moving.
22->B-turret index command was issued when work-out unit is not down position. Or work-out unit was not down position when B-turret is indexing.
23->Door close command was issued when work-out unit is not down position. Or work-out unit was not down position when door is closing.
24->A work-out unit down command was issued with the chuck not at the opened.
