Okuma Alarm-A 1922 Torque limit over
While the torque skip cycle is executed, the detected torque has exceeded the set limit before the loader axis reaches point D where deceleration starts.
Or while the torque skip cycle is excuted, the loader axis reached the point designated by the program before the torque skip occurs.
In a torque limit check instruction, a torque value exceeded set data in a transfer to target position + L.
1->Torque limit is executed before arriving at point D.
2->A loader axis has arrive at “target point + L” before torque limit exceeded.
3->Concerning torque limit check function, while axis reached target position + L, a torque value exceeded set data.
1)Setting error of parameter (torque monitor delay time)
2)Setting error for arguments in the G22 block
3)Setting error for arguments in the G23 block
