Okuma Alarm-A 8541 Spindle phase synchronization interlock
A practical condition of spindle phase synchronous commands does not have it been satisfied.
system
11->The spindle which is turned into the same phase is in revolution.
12->The spindle which is turned into the same phase is in indexing.
13->The spindle which is turned into the same phase is in C axis mode.
14->The spindle which is turned into the same phase is in practice S command.
16->The spindle gear which is turned into the same phase is in neutral condition.
17->The spindle which is turned into the same phase is in flat-turning mode.
18->The spindle which is turned into the same phase is in synchronous mode.
19->The spindle which is turned into the same phase is in lowest speed mode.
1A->The spindle which is turned into the same phase is in phase synchronous condition.
21->The spindle which does a phase same is in revolution.
22->The spindle which does a phase same is in indexing.
23->The spindle which does a phase same is in C axis mode.
24->The spindle which does a phase same is in practice S command.
25->The spindle chuck which does a phase same is in open status.
26->The spindle gear which does a phase same is in neutral condition.
27->The spindle which does a phase same is in flat-turning mode.
28->The spindle which does a phase same is in synchronous mode.
29->The spindle which does a phase same is in lowest speed mode.
2A->The spindle which does a phase same is in synchronous phase mode.
30->Concerning MacTurn-W/H2-turret,A subspindle is not a lower position condition.
