Okuma Alarm-A 8569 Magazine turn interlock
A magazine rotation command was issued though the magazine rotating conditions are not met.
XX
9->The sub arm is not in position for enabling magazine rotation.
10->The tool extraction pin at the magazine manual tool loading /unloading position is not set at clamp position.
11->For tool ID specification, the tool ID data reading arm is not in retract position.
12->A magazine pot is not unclamp.
13->There is not a magazine pot in a frontal change position.
14->There is exchange arm in EAMG position.
9)For LB35II-MATC-Y and LU45-MATC-Y, magazine rotation is possible only when the sub arm is in the RS position or directed to the RS. While the sub arm is in any other state, the magazine cannot rotate.
10),11)Magazine rotation is not possible in either of the following cases: the tool extraction pin at the magazine manual tool loading/unloading position is not set at clamp position, or the tool ID data reading arm is not in retract position.
12),13),14) By LB15II-MATC-Y, a magazine pot is 9)For LB35II-MATC-Y and LU45-MATC-Y, magazine rotation is possible only when the sub arm is in the RS position or directed to the RS. While the sub arm is in any other state, the magazine cannot rotate.
12),13),14) By LB15II-MATC-Y, a magazine pot is unclamp and is a frontal change position, and when there is exchange arm in EAMG position, it can be done magazine rotation.
