Okuma Alarm-A 8592 Synchronizing C-axis
1->The spindle rotation command was issued when C-axis was synchronous mode.
2->The spindle orientation command was issued when C-axis was synchronous mode.
3->The spindle gear change command was issued when C-axis was synchronous mode.
4->The C-axis connect ON/OFF command was issued when C-axis was synchronous mode.
5->The flat-turning command was issued when C-axis was synchronous mode.
6->The spindle synchronous rotation command was issued when C-axis was synchronous mode.
7->The spindle lowest speed mode command was issued when C-axis was synchronous mode.
8->The spindle phase synchronous mode command was issued when C-axis was synchronous mode.
