Okuma Alarm-A 8611 Winding change error
1->The state of spindle servo failed to come OFF before Winding-change.
2->The state of spindle servo failed to come ON after Winding-change.
3->Spindle parameter set number did not change correctly while Winding-change command was pending.
4->Spindle High winding input signals failed to turn OFF while low-speed coil selection command was pending.
5->Spindle Low winding input signals failed to turn OFF while high-speed coil selection command was pending.
6->Spindle Low winding input signals failed to turn ON while low-speed coil selection command was pending.
7->Spindle High winding input signals failed to turn ON while high-speed coil selection command was pending.
