Okuma Alarm-A 8617 Thru-the-tool coolant filter clogged
The filter within the thru-the-tool coolant tank is clogged.
1->The NC detected this alarm while outputting the high-pressure oil hole (through spindle coolant) pump motor ON signal.
2->The NC detected this alarm while outputting the washing gun motor ON signal.
1) The filter is clogged.
2) The clogging detection pressure switch is faulty.
Clean the filter.
