Okuma OSP-P300S/P300L Alarm-A list.
For cnc machinists who work on cnc machines with Okuma cnc controls.
Classification Of Okuma Alarms
Alarms related with the OSP are classified into five types, which are
- Alarm P
- Alarm A (listed below)
- Alarm B
- Alarm C
- Alarm D
- ERROR
Below are listed Okuma A type alarms for Okuma OSP-P300S/P300L CNC systems.
Okuma Alarm A List
- 1071 Memory board battery depleted. Replace quickly!
- 1089 PLC alarm No. illegal
- 1091 PLC alarm message file not found
- 1092 PLC backup data file write
- 1093 PLC backup data file not found
- 1094 PLC back up data file read
- 1097 Safety speed monitor error
- 1098 MCS not responsive
- 1100 Parameters not set
- 1101 Blue screen
- 1102 P100-Menu error
- 1103 AlarmService internal error
- 1104 DeviceNet slave idle mode
- 1105 DTL error
- 1106 FL-net initialization error
- 1107 Major FL-net error
- 1108 Non-responsive software detected
- 1109 Error occurred during CAS
- 1110 PLC control error
- 1111 Shutting down to avoid damage
- 1112 Non-functioning device detected
- 1113 MCS Parameter learning error
- 1114 MCS Inertia identification error
- 1120 Overload detected.
- 1121 PSC Optical scale encoder error
- 1122 Safety controller error
- 1123 Safety speed monitor error
- 1132 VDU communication error
- 1133 VDU detected error
- 1134 VDU initialization failure
- 1135 MCS DD encoder link error
- 1136 MCS DD encoder error
- 1137 MCS DD Encoder (slave sensor) error
- 1138 MCS DD encoder initialization failure
- 1139 MCS DD encoder (slave sensor) initialization failure
- 1144 MCS Power supply unit overload
- 1146 Tailstock torque over
- 1150 MCS Undefined alarm number
- 1151 MCS Inverter unit fault
- 1152 Mistake in data from MCS to NC
- 1153 MCS CON APA deviation
- 1154 MCS Power supply unit error
- 1155 MCS Converter link error
- 1156 MCS DC-bus voltage alarm
- 1157 MCS Motor overcurrent
- 1158 MCS Power unit overheat
- 1159 MCS Power unit overload
- 1160 MCS Supply voltage flutter
- 1161 MCS Inverter capacity differs from spec.
- 1162 MCS Winding change failure
- 1163 MCS Encoder link error
- 1164 MCS Encoder detected error
- 1165 MCS Encoder initialization failure
- 1166 MCS Encoder with shaft detected error
- 1167 MCS Encoder with shaft initialization failure
- 1168 MCS ABSO SCALE error
- 1169 MCS ABSO SCALE initialization failure
- 1170 MCS Magnetic encoder alarm
- 1171 MCS Resolver alarm
- 1172 MCS Pulse generator count over
- 1173 MCS Motor overheat
- 1174 MCS Servo link error
- 1175 MCS Servo link disconnection
- 1176 Mistake in data from NC to MCS
- 1177 MCS Servo data error
- 1178 MCS Illegal command
- 1179 MCS CON speed over
- 1180 MCS Speed command over
- 1181 MCS DIFF over
- 1182 MCS APA speed over
- 1183 MCS Full-closed APA error
- 1184 MCS Over speed
- 1185 MCS Speed deviation over
- 1186 MCS Collision detected
- 1187 MCS Urgent-stop time over
- 1188 MCS Belt is broken
- 1189 MCS Axis change control error
- 1190 MCS Independent encoder initialization failure
- 1191 MCS Calculated current position lies outside range
- 1192 MCS Motor overload
- 1194 MCS ABSO SCALE sub-slider error
- 1195 MCS Tandem control communication error
- 1196 MCS Full abso scale link error
- 1197 MCS Full abso scale error
- 1198 MCS Full abso scale initialization failure
- 1199 MCS Axis stop signal error
- 1200 Stroke end over
- 1202 Plus variable limit over
- 1203 Minus variable limit over
- 1213 User reserve code
- 1215 S.M command asynchronous
- 1216 Synchronous P code error
- 1217 Torque limiter
- 1218 Torque limiter cancel
- 1219 Torque limit over
- 1220 Torque skip condition not satisfied
- 1221 Duplicate M-code
- 1222 Interrupt return pointer mismatch
- 1223 Thread feed command error
- 1225 Contour generation calculation error
- 1228 Illegal spindle mode
- 1229 Max. spindle rotation count not specified
- 1238 Spindle moved to interference distance
- 1243 Turret rotation conditions
- 1245 Axis moved to tool interference area
- 1257 Axis moved to chuck barrier area
- 1258 Axis moved to tailstock barrier area
- 1259 Tow-along tailstock connecting
- 1260 Tow-along tailstock command not possible
- 1262 W-axis plus variable limit over
- 1263 W-axis minus variable limit over
- 1265 Parts catcher interlock
- 1272 Load exceeds No.2 limit value
- 1273 Load monitor command already executed
- 1278 Laser measurement data NG
- 1279 IND. CMP. data verification failure
- 1280 HP9825A unable to receive
- 1281 Abnormal data from HP9825A
- 1282 Data error from HP9825A
- 1283 C-axis command not possible
- 1299 Axis moved to sub-spindle interference distance
- 1300 W-axis unable to move
- 1303 Pickoff index position
- 1306 Sensor touch G00
- 1307 No contact with sensor
- 1309 Sensor protect
- 1316 ATC manual operation mode impossible
- 1322 Y-axis parameter illegal
- 1323 Illegal YS-axis position
- 1328 Adaptive control communication error
- 1329 Shift amount error
- 1332 Spindle belt slip
- 1334 APA error
- 1336 Moved inside horizontal barrier area
- 1338 LOAD MONITOR W overload
- 1339 Spindle different from position when door open
- 1345 Unable to move to tool change position
- 1347 STM time over
- 1348 Cycle time over
- 1349 Contour generation impossible
- 1353 Measurement system error
- 1355 Tow-along steady rest connected
- 1356 Steady rest torque over
- 1357 Positioning uncertain
- 1367 NC tailstock position error
- 1376 Cutting error
- 1393 Tow-along steady rest interference position
- 1412 HOME POSITION movement interlock
- 1426 Moved inside barrier area
- 1431 Safety speed over
- 1432 Safety monitor error detection
- 1435 Turret interference
- 1436 Power ON APA deviation
- 1440 Steady rest-Tailstock interlock
- 1441 Safety speed clamp
- 1453 Heavy work data not found
- 1460 TEMP RISE LIMIT OVER
- 1463 Spindle moved inside transportation barrier
- 1465 Spindle low acceleration mode condition
- 1466 HOB cutting overload
- 1467 Position scale error XS-axis
- 1468 Servo amp error XS-axis
- 1469 APA speed XS-axis
- 1470 APA range XS-axis
- 1471 CON speed XS-axis
- 1472 Stroke end over XS-axis
- 1473 Actual position initialization error XS-axis
- 1474 Learning control error XS AXIS
- 1475 CAM execution data not selected XS-axis
- 1476 Learning control command XS-axis
- 1477 Syncronous mode command
- 1478 Chuck coordinates mismatch
- 1479 PSCB command error
- 1480 DIFF over XS-axis
- 1481 Drift compensation value over
- 1482 PSCB Real-time task error
- 1483 PSCB INT task loop error
- 1484 PSCB EC task loop error
- 1485 PSCB Time sharing task error
- 1486 PSCB Exception error
- 1487 PSCB Memory test error
- 1488 PSCB Overheat
- 1489 First time drift compensation value over
- 1490 Synchronous mode spindle speed command
- 1491 Heavy tooling data not found
- 1492 PSCB P.G. underpulse
- 1493 PSCB P.G. overpulse
- 1494 PSCB Minus stroke end over
- 1500 Workpiece rest interlock
- 1501 Workpiece rest torque over
- 1504 Alarm-A at other system
- 1507 Unable to enter C-axis sync. Mode
- 1509 A turret and B turret interference
- 1510 Unable to execute Hi-CUT Pro control
- 1511 SPM contour control not possible
- 1512 SPM contour control error
- 1513 Unable to clamp workpiece
- 1514 Clutch A slip over limit
- 1515 Mistake in X, Z commands
- 1516 NC tailstock slide resistance over
- 1517 Turret or tool not at index cut position
- 1519 Spindle phase over limit
- 1520 Synchronous error limit over
- 1521 NC tailstock error
- 1522 Linear guide cover interference area
- 1523 Workpiece weight data file not found
- 1524 Feed speed over
- 1525 M-tool spindle speed over in Hob mode
- 1526 Turret index error position
- 1527 Unable to execute while mounting LBB
- 1528 The attachment status mismatch
- 1529 M axis belt slip
- 1530 Steady-rests interference position
- 1531 Tool posture fluctuation reduction error
- 1532 Turret interference distance intrusion
- 1682 Magnetic encoder speed detection error
- 1683 MCS Rotary encoder 5 initialization failure
- 1684 MCS Rotary encoder 5 error
- 1685 MCS Rotary encoder 4 initialization failure
- 1686 MCS Rotary encoder 4 error
- 1687 MCS Rotary encoder 3 initialization failure
- 1688 MCS Rotary encoder 3 error
- 1689 MCS Rotary encoder 2 error
- 1690 MCS Rotary encoder 1 initialization failure
- 1691 MCS Rotary encoder 1 error
- 1692 MCS Linear scale 4 initialization failure
- 1693 MCS Linear scale 4 error
- 1694 MCS Linear scale 3 initialization failure
- 1695 MCS Linear scale 3 error
- 1696 MCS Linear scale 2 initialization failure
- 1697 MCS Linear scale 2 error
- 1698 MCS Linear scale 1 initialization failure
- 1699 MCS Linear scale 1 error
- 1700 Emergency stop
- 1701 EC overload
- 1702 BDU overload
- 1703 EC circuit breaker
- 1704 Transformer overheat
- 1705 Oil pressure low
- 1706 Alarm detected from externally connected device
- 1707 Stroke end over
- 1708 Canceling stroke end limit
- 1709 XA-axis overload
- 1710 XB-axis overload
- 1711 ZA-axis overload
- 1712 ZB-axis overload
- 1713 Spindle rotation interlock
- 1714 S.M command asynchronous
- 1715 Spindle revolution over
- 1716 M03/M04 change command failure
- 1717 Unable to use M40, M43, M44 commands
- 1718 Tow-along tailstock command error
- 1719 Gear command/position mismatch
- 1720 Gear command error
- 1721 Gear neutral
- 1722 M19 command issued when gear neutral
- 1723 Z-axis moved to spindle interference distance
- 1724 Spindle synchronization interlock
- 1725 Impossible command issued during spindle synchronization
- 1726 C-axis command not possible
- 1727 C-axis ON/OFF command not possible
- 1728 C-axis clamp/unclamp command not possible
- 1729 Unable to confirm C-axis advance
- 1730 Turret clamp/position check error
- 1731 Turret index control alarm
- 1732 Turret rotation interlock
- 1733 Tool number input error
- 1734 Pickoff chuck interlock
- 1735 Sub-spindle chuck pressure insufficient
- 1736 Pickoff index interlock
- 1737 Turret unclamp interlock
- 1738 Turret rotation impossible
- 1739 Chuck clamp pressure insufficient
- 1740 Chuck open/close interlock
- 1741 Chuck unclamp
- 1742 Chuck interlock cancel interlock
- 1743 Index chuck interlock
- 1744 Air chuck pressure error
- 1745 Chucking miss
- 1746 Chuck missclamp
- 1747 No tailstock quill advance answer
- 1748 Tailstock quill advance over
- 1749 Tailstock quill command error
- 1750 Tailstock interference
- 1751 Tow-along tailstock ON/OFF interlock
- 1752 Tow-along tailstock clamp/unclamp error
- 1753 Parts catcher interlock
- 1754 Coupling device alarm
- 1755 Robot inside machine
- 1756 Loader inside machine
- 1757 Loader interlock
- 1758 Loader not at escape position
- 1759 Loader/robot not at escape position
- 1760 Revolution tool M13/M14 change not possible
- 1761 Revolution tool gear mismatch
- 1762 Revolution tool gear interlock
- 1763 Tool revolution interlock
- 1764 Tool rotating when T command issued
- 1765 Rotation tool index interlock
- 1766 Rotation tool over speed
- 1767 M-axis clutch connection error
- 1768 Sub-spindle rotation over
- 1769 Sub-spindle index interlock
- 1770 Door interlock
- 1771 Door open/close limit switch NG
- 1772 Door open/close condition
- 1773 Unable to restore axis position when door closed
- 1774 Sensor head advance/retract interlock
- 1775 Touch setter limit
- 1776 Sensor head not at retract position
- 1777 ATC change arm position error
- 1778 No dummy tool in ATC turret
- 1779 Manual tool change operation interlock
- 1780 ATC system mode interlock
- 1781 Loader/robot interference
- 1782 Power sequence error
- 1783 Turret unclamp time over
- 1784 Turret clamp time over
- 1785 NC parameter data transfer error
- 1786 Coolant error
- 1787 Door open/close check NG
- 1788 Safety door open
- 1789 Steady rest interlock
- 1790 Bar feeder not ready
- 1791 Bar feeder advance/retract interlock
- 1792 Turret rotation interlock
- 1793 Side cover interlock
- 1794 Rear cover interlock
- 1795 Side cover open/close lmt switch NG
- 1796 Turret index clutch disconnect error
- 1797 Invalid mode switch
- 1798 Steady rest missclamp
- 1799 Sensor protection cover interlock
- 1800 Locking switch NG
- 1801 Bar feeder setting position mismatch
- 1802 Safety guard interlock
- 1803 Machine enabling button error
- 1804 Safety speed monitor output error
- 1805 Teaching panel enabling switch error
- 1806 ATC Logic data file error
- 1807 Shutter close not possible
- 1808 Safety fence locking switch NG
- 1809 Manual command time over
- 1810 Safety guard interlock
- 1811 Loader axis unable to move
- 1812 Mist lubrication unit error
- 1813 2nd spindle condition satisfy
- 1814 W-axis movement interlock
- 1815 Face driver pressure insufficient
- 1816 Safety fence open
- 1817 Setup switch ON
- 1818 Hand slide interlock
- 1819 Hand turning interlock
- 1820 Turnover interlock
- 1821 Magazine door lock error
- 1822 Slide step interlock
- 1823 Vibration cutter faulty
- 1824 Oil cooler error
- 1825 Spindle cooling unit error
- 1826 Oil air lubrication illegal
- 1827 Setup switch ON
- 1828 Laser sensor interlock
- 1829 Sp. oil air lub. air pressure error
- 1830 SP. oil air lub. oil level error
- 1831 Sp. oil air lub. oil pressure error
- 1832 Unloader advance/retract interlock
- 1833 Tow-along steady rest unclamp interlock
- 1834 Door interlock
- 1835 Workpiece receiver interlock
- 1836 Interference area intrusion
- 1837 Worktable overload
- 1838 Workpiece stabilizer interlock
- 1839 Deburring tool interlock
- 1840 M code data file mismatch
- 1841 Swing interlock
- 1842 Wrist rotation interlock
- 1843 Workpiece rest interlock
- 1844 Workpiece pusher interlock
- 1845 Hand rotation interlock
- 1846 Chuck grip confirmation unit faulty
- 1847 Tailstock air miss detection input NG
- 1848 Chuck grip failure
- 1849 Workpiece unloading unit interlock
- 1850 Robot/Loader emergency stop
- 1851 Air pressure insufficient
- 1852 NC alarm
- 1853 Oil pressure insufficient
- 1854 Error detected from externally connected device
- 1855 M code time over
- 1856 Circuit breaker tripped
- 1857 Intrusion interlock
- 1858 No hand open/close output
- 1859 Swing position no output
- 1860 Axis interlock
- 1861 Stroke end over
- 1862 Canceling stroke end limit
- 1863 Loader interference
- 1864 Z/C-axis not in rotation possible area
- 1865 Swing position indefinite
- 1866 No workpiece clamped on hand A
- 1867 No workpiece clamped on hand B
- 1868 Wrist broken
- 1869 Hand open/ close interlock
- 1870 Hand clamp confirmation
- 1871 Coupling device error
- 1872 Safety fence interlock
- 1873 Door interlock
- 1874 Interlock release NG
- 1875 Safety fence lock NG
- 1876 Swing interlock
- 1877 Robot/Loader power sequence error
- 1878 Machine start impossible
- 1879 Workpiece puller holder interlock
- 1880 Loader hand/machine interference
- 1881 Part turnover device R clamp empty
- 1882 Part turnover device L clamp empty
- 1883 Part turnover device R advanced too far
- 1884 Part turnover device L advanced too far
- 1885 Loader/part turnover device interference
- 1886 Wrist turning position indefinite
- 1887 Workpiece puller interlock
- 1888 Backup roller interlock
- 1889 Auto workpiece I/O unit FWD pressure low
- 1890 Coolant flow insufficient
- 1891 Unloader interference position
- 1892 Unloader interlock
- 1893 Running mode error
- 1894 Running mode error
- 1895 Fire alarm
- 1896 Air source pressure low
- 1897 Lower turret drive belt torn
- 1898 OP panel within interference range
- 1899 Safety fence open
- 1900 Plus variable limit over
- 1901 Minus variable limit over
- 1920 User reserve code
- 1922 Torque limit over
- 1924 Barrier intrusion
- 1927 M code time over
- 1928 Cycle time over
- 1938 Machine start impossible
- 1939 Hand open/close interlock
- 1940 Loader Z-axis stopper set
- 1941 Safety guard interlock
- 1942 Safety speed over
- 1943 Safety speed monitor error
- 1944 Safety monitor error detection
- 1945 Running mode error
- 1949 Alarm-A at other system
- 1950 Safety speed monitor error
- 1951 Safety controller error
- 8500 Cut off error
- 8501 ATC shutter not close
- 8502 Unable to G21
- 8503 Spindle internal centering unit interlock
- 8504 Tool change command
- 8505 Tow-along steady rest clamp/unclamp
- 8506 Combination chuck interlock
- 8507 Automatic lubrication system error
- 8508 Coolant filter
- 8509 Cutting feed interlock
- 8510 Oil unit error
- 8511 B-axis clamp/unclamp interlock
- 8512 Turret position uncertain
- 8513 Coolant interlock
- 8514 Work conveyor interlock
- 8515 Work ejector interlock
- 8516 Touch setter unlock time over
- 8517 Work hand interlock
- 8518 Bar Feeder illegal
- 8520 Stopper interlock
- 8521 Work measurement operation
- 8522 Locater oil pressure
- 8523 Locater condition
- 8524 Oil motor overload
- 8525 Coolant motor overload
- 8526 Spindle cooling motor overload
- 8527 Oil skimmer overload
- 8528 Magnet separator overload
- 8529 Tool monitoring unit error detection
- 8530 Laser sensor input data error
- 8531 Door open
- 8532 Polish Material unit interlock
- 8536 Operation ready OFF condition
- 8537 Magazine door Interlock
- 8538 ATC shutter barrier area
- 8539 Complete stop
- 8540 X-axis in interference range
- 8541 Spindle phase synchronization interlock
- 8542 Synchronizing spindle phase
- 8543 Measurement Unit error
- 8545 Illegal robot/loader request
- 8546 Rolling-head movement error
- 8547 Drive jig unit interlock
- 8548 ACC interlock
- 8549 ACC door interlock
- 8550 ACC manual operation mode impossible
- 8551 Semi-dry unit error
- 8552 Sub-chuck interlock
- 8553 ACC airblow interlock
- 8554 Spindle table rotation
- 8555 B-Axis movement
- 8556 No mount magazine
- 8557 Tool Breakage sensor error
- 8558 L-tool index command
- 8559 Part turn device advanced too far
- 8560 Override switch failure
- 8561 Grinding whl spindle motor overload
- 8562 Whl spdl coolant pressure drop/loss
- 8563 Inverter failure
- 8564 Turret drive belt disconnection
- 8566 Tool clamp interlock
- 8567 Spindle cover open/close limit SW NG
- 8568 Insulation error
- 8569 Magazine turn interlock
- 8570 Magazine tool No.
- 8571 Irregular coolant level
- 8572 ATC step time over
- 8573 Spingdle vibration
- 8574 MCS operation ready off
- 8575 Grinding whl spindle unit
- 8576 Grinding whl spindle unit interlock
- 8577 Axis interlock
- 8578 Coupling device interlock
- 8579 Tailstock and turret interference
- 8580 Canceling interference detection
- 8581 Loader automatic operation
- 8582 Illegal workpiece pusher confirmation
- 8583 ATC change arm overload
- 8584 Tailstock high/low change interlock
- 8585 Coiling prevention equip. interlock
- 8586 Air picker broken
- 8587 AREA SENSOR interlock
- 8588 Coolant Flow
- 8589 Chip conveyor faulty
- 8590 Tailstock pedestal condition
- 8591 C-axis synchronous condition
- 8592 Synchronizing C-axis
- 8593 Chip crusher error
- 8594 Sensor overstroke
- 8595 Linear guide cover interference
- 8596 Safety plug interlock
- 8597 Shuttle device hand clamp empty
- 8598 Ceiling door interlock
- 8599 Illegal tool clamp unit
- 8600 Ceiling door open/close limit SW NG
- 8601 ATC tool change arm inverter failure
- 8602 Chip pan cover interlock
- 8603 C-axis clamp/unclamp condition
- 8604 Long tool change protection
- 8605 Drive belt disconnection
- 8606 APC door open/close limit NG
- 8607 XB cover interference
- 8608 Illegal touch setter unit
- 8609 Axis overheat
- 8610 Invalid spindle winding condition
- 8611 Winding change error
- 8612 APC interlock
- 8613 APC clamp/unclamp time over
- 8614 APC escape position
- 8615 ATC shutter not open
- 8616 Coolant level low
- 8617 Thru-the-tool coolant filter clogged
- 8618 M spindle overload
- 8619 Machine axis travel limit over
- 8620 PLC system data
- 8621 M spindle air curtain pressure low
- 8622 Hydraulic unit oil level low
- 8623 Mist air lubrication unit
- 8624 Axis interlock
- 8625 Tool revolution command
- 8626 Ceiling door guide interlock
- 8627 Long boring bar change protection
- 8628 Spindlehead lib oil level low
- 8629 Spindlehead lubricant pressure low
- 8630 Hydraulic pressure drop
- 8631 Invalid safety-monitor spec.
- 8632 UNUSABLE interrupt program
- 8633 AAC Operation mode impossible
- 8634 ATC shutter open/close condition
- 8635 Spindle actual position detection error
- 8636 RSS unit Battery error
- 8637 RSS unit Communication error
- 8638 Sub-spindle head clamp condition
- 8639 Tailstock control mode ON/OFF cond.
- 8640 Center partition interlock
- 8643 Unusable PLC spec. code
- 8644 Fire extinguish unit power OFF
- 8645 Fire extinguish unit error
- 8646 Fire ext. unit power OFF or error
- 8647 Hand open/close switch NG
- 8648 Tailstock tool mode mismatch
- 8649 Measurement sensor unit interlock
- 8680 Area sensor interlock
