Okuma Alarm-B 2210 Spindle max revolution error
Spindle max.[1/min] designating S command value is greater than the value set at the MC USER PARAMETER (SPINDLE)
Allowable chuck rotation speed.
Or the G50 S**** (spindle max.[1/min] designation) is designated in the program block which contains an axis command.
Character-string:Coordinate system for G140, G141, or G142.
1->Spindle max.[1/min] designating S command value is greater than the value set at the MC USER PARAMETER
(SPINDLE) Allowable chuck rotation speed.
2->The G50 S*** is designated in the block which contains an axis command.
Program error
