Okuma Alarm-B 2216 System variable setting data over
Setting value of the system variable has exceeded the allowable limit.
Allowable setting range (ex.)
Droop amount
0 through 1.000
Tool nose radius compensation value
-999.999 through 999.999
Tool offset value
-99999.999 through 99999.999
Plus variable limit <= Plus travel end limitMinus variable limit >= Minus travel end limit
The plus (minus) travel end limit value is set at the system parameter.
When the spec of TOOL LIFE MANAGEMENT was OFF, command of “VOLPR=10,11,12” was ordered.
Hexadecimal number of set value
System variable
Operation Example:
In parameter setting mode, “2” is set as the droop amount at the user parameter.
Set the system variable so that a tolerance will not be exceeded.
