Okuma Alarm-B 2242 Mistake in J command
Illegal J command
Numerical value of J command is not: 0 < J<=99999.999.Or, J command is not designated with G36 or G37.Object
1->J value is negative
2->J value does not satisfy: 0 < J<=99999.9994->J value of G265 block is outside the range.
J command
Program Example:
G33 X50 Z20 F0.2 J-5[Code]1
Change J command value so that it is within the allowable range.
Example:
G33 X50 Z20 F0.2 J5
