Okuma Alarm-B 2246 Mistake in S command
Illegal S command
Numerical value of S command is not: 0<=S<=9999Or, there was not S=0 or S instruction at the time of a Main spindle synchronization tap cycle instruction.Object
Hexadecimal number of programmed S command or $FFFFFFFF
Hexadecimal number of programmed S command : S instruction of S instruction is not 0
$FFFFFFFF : When Main spindle synchronization tap cycle instruction, there was not S=0 or S instruction.
S command
Program Example:
N010 G00 X500 Z500 M42 S10000 T0101
Change S command value so that it is within the allowable range.
Example:
N010 G00 X500 Z500 M42 S3000 T0101
