Okuma Alarm-B 2248 Mistake in T command
Illegal T command
In T******, respective two-digit numbers expressing tool number, tool offset number and tool nose radius compensation number
are larger than 32. (96 for 96-pair specification)
Or, the order of edge-number was larger than the number of tool-edges. (for the spec of “Many chips tool”)
The spec.of “Tool offset over-200”:
If command was “Tooo***”, “***” was wrong.
Hexadecimal number of the designated T command when it is not:0
T command
Program Example:
T011156->[Code]B0038
T243512->[Code]C0023
T1120101->[Code]650070
T-1->[Code]FFFFFFFF
T100000000->[Code]5F5E100
Specify T commands in four or six digits;
each two digits of command must be 32 (96 in the case of 96-pair specification) or smaller.
