Okuma Alarm-B 2259 Mistake in SB command
Designated SB command is not: 0<=SB<=60000SB command is designated for B-turret.Object
1->SB command is designated for B-turret.
Others->Hexadecimal number of commanded SB value
Program error
Program Example:
N010 M13 SB=65000
Check the SB command; check whether the SB command is designated at the B-turret side.
In the example program above, the SB command value is greater than 60000; correct the program.
N010 M13 SB=60000
