Okuma Alarm-B 2264 Mistake in Y command
For coordinate system conversion, the numerical value of “Y” is not within the following range: -99999.999<=Y<=99999.999If this alarm occurs in a case other than coordinate conversion, see the following codes.Code
Hexadecimal number of the Y command value specified for coordinate conversion
1->Y command is issued without specifying G00,G01,G02,G03,G30,G18?, or G50.
3->Y command value is not in the range -99999.999 =< Y =< 99999.999.7->Y-axis command was issued in a mode other than Y-axis control mode or coordinate conversion mode.
Or Y-axis command was issued without the positioning G code when Y-axis CENTER COMP. function was effective.
