Okuma Alarm-B 2272 Mistake in TM command
Illegal TM command
A number greater than the number of turret tools set at the parameter is designated for “oo” in the “TM = oo**” command.
Or no value is set for the parameter.
Or, a number greater than “32” is designated for “**”.
The spec.of “Tool offset over-200”:
If command was “TM=ooo***”, “***” was wrong.
Parameter
MC SYSTEM PARAMETER (TURRET/DOOR)
Number of tools on turret A-side
Number of tools on turret B-side
If a TM command is outside 0 < TM < 99999999, the hexadecimal number of the commanded TM value.If the tool number is greater than the number of turret tools or the tool offset number is greater than the "32", the hexadecimal number of the designated number in the lower four digits.Probable Faulty Locations
TM command value
Program Example:
G14 TM =0233 :
Check the TM command value.
G14 TM =0232 :Okuma Alarm-B 2272 Mistake in TM command
