Okuma Alarm-B 2334 In-process gauging no spec.
In-process work gauging variables are designated or the gauging cycle is programmed although the control has no in-process gauging specification.
1->In-process gauging variables are programmed in left part.
2->In-process gauging variables are programmed in right part.
3->Gauging cycle is programmed.
4->Though there is not a Y-axis measure specification, in Y-axis measure cycle command is designated.
5->Though there is not a measure within a machine specification or a touch setter specification, in measure cycle command is designated.
Program error
Program Example:
N010 VRNGZ = 100.000(VRNGZ is the in-process gauging variable.)
Eliminate the in-process gauging variable or gauging cycle command from the program.
