Okuma Alarm-B 2339 Load monitor no spec.
When the load monitor specification is not selected,
System-variable of Load monitor or CLEAR command is designated.
->On the machine without load monitor function, the load monitor command “VLMON” or “CLEAR” was issued.
System-variable of Load monitor data “VLM?B”,”VLM?1″, “VLM?2” was issued. ( = Z,X,C,S,M,W,B,Y )
System-variable “VOLPR” was ordered.
1->On the machine without load-monitor-W function, the load-monitor-W command “VWMON” was issued.
1)”VLMON” or “CLEAR”,”VLM?B”,”VLM?1″,”VLM?2″ is specified in a program for the control which does not support the monitor specification. ( ? = Z,X,C,S,M,W,B,Y )
The commands above are input in the MDI mode.
2)On the machine without load-monitor-W function, the load-monitor-W command “VWMON” was specified in the program or issued in MDI mode.
1)Correct the program;delete “VLMON” or “CLEAR”,”VLM?B”, “VLM?1″,”VLM?2” command from the program.
2)Correct the program;delete VWMON command from the program.
3)Correct the program;delete VOLPR command from the program.
