Okuma Alarm-B 2390 LAP Entry in NOSE-R comp.
While nose radius compensation mode is active, G code calling for LAP mode (G85, G86, G87 and G88) is designated.
G85: Calls rough bar turning cycle.
G86: Calls rough copy turning cycle.
G87: Calls finish turning cycle.
G88: Calls continuous thread cutting cycle.
Program error
Program Example:
N010 G41 X-- Z--
: <- G40 is not specified here.
N020 G85 NLAP1...No G40 command designated within these blocks.
Check the LAP commands (G85, G86, G87 and G88) in the blocks where the nose R compensation mode is active.
In the example program above, it is necessary to cancel the nose R compensation function before the G85 command.
N010 G41 G00 X-- Z--
N019 G40 X-- Z--
N020 G85 NLAP1 ...
