Okuma Alarm-B 2418 MULTI-MACHINING CYCLE Q
Designated Q value is not: 1 <= Q <= 9999Q: Used to specify the number of equidistant holes or machining points for the compound fixed cycle repeating function.Object
Hexadecimal number of designated Q value
Faulty program (compound fixed cycle block)
Program Example:
G183 X40 Z81 C0 I46 D10 E1 F40 Q10000
Check the Q command in the compound fixed cycle block.
G183 X40 Z81 C0 I46 D10 E1 F40 Q6
Related Specifications
Multi-machining model
