Okuma Alarm-B 2419 MULTI-MACHINING CYCLE F
Designated F(cutting feedrate) value is either 0 or negative.
E command value designated with G190 or G192 is either 0 or negative.
No F command
FFFFFFFF->No F command
Others:Hexadecimal number of designated E or F value
Faulty program (compound fixed cycle block)
Program Example:
G183 X40 Z80 C0 I46 D10 E1 F-40
Check the E or F command in the compound fixed cycle block.
G183 X40 Z80 C0 I46 D10 E1 F40
Related Specifications
Multi-machining model
