Okuma Alarm-B 2420 MULTI-MACHINING CYCLE L
Designated L value is not: 0 < L <= 99999.999L: Return amount to the cutting start point in deep hole drilling cycleL: Return amount to the cutting start point in deep hole synchronization tapObject
FFFFFFFF->L<=LK("Pecking amount in tapping cycle" of an OPTIONAL PARAMETER(MULTIPLE MACHINING) is used when there is no LK value. )FFFFFFFE->A different processing pattern instruction was done at the synchronization tap cycle of a continuous block.
Others->Hexadecimal number of designated L value
Faulty program (compound fixed cycle block)
Program Example1:
G183 X40 Z80 C0 I46 D10 E1 F40 L-50
<- It is outside the range.G178 X40 Z80 C0 I46 D10 F40 L0.001<- It is smaller than the parameter value.Program Example2:G178 X50 Z50 F=100 K10 LD=10 <- There is no L value.X70 Z30 L20 <- There is L value.Measures to Take
Check the L command in the compound fixed cycle block.
G183 X40 Z80 C0 I46 D10 E1 F40 L50
Related Specifications
Multi-machining model
