Okuma Alarm-B 2421 MULTI-MACHINING CYCLE D
No D command
Designated D value is not: 0 < D <= 99999.999D: A depth of cut in keyway cutting before deep hole drilling cycleObject
FFFFFFFF->No D command
Others:Hexadecimal number of designated D value
Faulty program (compound fixed cycle block)
Program Example:
G183 X40 Z80 C0 I46 E1 F40 L50
Check the D command in the compound fixed cycle block.
G183 X40 Z80 C0 I46 D10 E1 F40 L50
Related Specifications
Multi-machining model
