Okuma Alarm-B 2422 MULTI-MACHINING CYCLE X,Z
In the block containing G185 through G188, either X or Z is not designated. Or, numerical value of X and Z is not:
-99999.999 <= X, Z <= 99999.999G185: Thread cutting cycle (side face)G186: Thread cutting cycle (end face)G187: Straight thread cutting cycle (side face)G188: Straight thread cutting cycle (end face)Object
FFFFFFFF->No X and Z command
FFFFFFFE->In the G297 command, It instructed the same position as the start point in the cutting target point
Others:Hexadecimal number of designated X and Z value
Faulty program (compound fixed cycle block)
Program Example:
G185 X95 C0 F10 SA=12
Check the X or Z command in the compound fixed cycle block.
G185 X95 Z60 C0 F10 SA=12
Related Specifications
Multi-machining model
