Okuma Alarm-B 2425 MULTI-MACHINING CYCLE A
In thread cutting cycle, X-axis travel calculated from A command value is not in the range from -99999999 to 99999999.
Hexadecimal number of X-axis travel calculated from A command
Faulty program (for compound fixed cycle block)
Program Example:
G185 X50 Z100 C45 A90 F3 SA=10 ..Wrong G185 X50 Z100 C45 A30 F3 SA=10 ..Correct
Check the A command in the compound fixed cycle.
Related Specifications
Multi-machining model
