Okuma Alarm-B 2431 ATC syntax
On the turret without ATC function, an ATC related command was issued. T, TC, and TL commands are issued at the same time.
TC: Turret index command to ATC position (TC = ##, where ## is the turret No.)
TL: Tool number index command (TL = &&$$%%, where && is the nose R compensation No., $$ is the tool No. and %% is the tool offset No.)
Program error
Check if the ATC related commands are correctly specified.
