Okuma Alarm-B 2434 ATC TL
An improper value is specified as the TL command value.
Indexing a tool not mounted on the turret was attempted with the TL command.
The sequence restart function was used to restart a program which incorporates a TL command for indexing a tool number not mounted in the turret.
TL:Tool number index command
(TL = &&$$%%,
where && is the nose R compensation No.,
$$ is the tool No. and
%% is the tool offset No.)
Or, the order of edge-number was larger than the number of tool-edges. (for the spec of “Many chips tool”)
Or, in the case of “TOOL OFFSET 999” spec and “MULTI EDGE TOOL” spec, tool number were not the following ranges.
MULTI-TOOL 8-EDGES:1-210 or 281-999
MULTI-TOOL 12-EDGES:1-210 or 321-999
Ordered Tool-number.
FFFFFFFF->In TOOL-ID spec
When the edge-number was ordered, code was “edge & holder-number (HEX)”.
When conducting a sequence restart, ensure that the tools mounted in the turret match the tools specified in the program.
