Okuma Alarm-B 2445 3-D coordinate conversion
G303/G302 command is wrong.
1->G303/G302 command is designated though the 3-D Coordinate conversion specification is not provided.
2->CP instruction is outside the range.
-359.999 <= CP <= 359.999[deg.]
3->CQ instruction is outside the range.
-359.999 <= CQ <= 359.999[deg.]
4->CR instruction is outside the range.
-359.999 <= CR <= 359.999[deg.]
5->H instruction is outside the range.
H = 1
6->It instructed in X/Y/Z/CP/CQ/CR and H when instructing in G303 at the same time.
7->Rotation axis (CP/CQ/CR) was not instructed in when instructing in G303. Or, there were two rotation axis instructions or more in the same block.
8->It instructed in G303 H when the 3-D Coordinate parameter was a unsetting.
9->It instructed in G11 as follows.
NO Y axis mode
G127-mode
Multi cycle mode
Lap mode
During the cutter radius compensation mode (Nose radius compensation mode)
G11-mode
COPY-mode
G117-mode
G255-mode
G265-mode
M556-mode
10->It instructed in the G302/G303 mode as follows.
Helical cutting
G20
G21
G22
G24
G25
G30
G31/G32
G33
G34/G35
G62
G71/G72
G73/G74
G77/G78
G80-G88
G101-G103
G107/G108
G112/G113
G116/G117
G126/G127
G131
G132/G133
G136/G137/G138
G140/G141
G152/G153
G185-G188
G254/G255
G264/G265
G269
M555/M556
M798/M799
11->All X/Y/Z are not instructed in by the first axis movement instruction after the offset(zero offset, zero shift, and tool offset) is changed.
Incorrect program
Correct the program.
