Okuma Alarm-B 2456 W-axis minus variable limit over
A W command exceeding the variable limit in the negative direction is designated.
Faulty program, or setting error of parameter (W-axis minus variable limit)
Check the W-axis command and the value set at parameter (W-axis minus variable limit).
