Okuma Alarm-B 2457 X-axis correction stroke end over
In Y-axis command or XY-axis command under Y-axis control, the XA-axis target point, which includes the X-axis compensation required for Y-axis movement, exceeds its stroke end.
1->Exceeds the minus stroke end.
2->Exceeds the plus stroke end.
1), 2) Programming error
Change the X-axis position so that the X-axis compensating motion for Y-axis movement does not exceed the X-axis travel end limits.
